05-19-2011
Not Finished Yet
Originally Posted by FishFinder
My hose is new (in this case white sani-hose from Trident), fittings are new, hose clamps are new. The fittings definitely match the hose, it's a good fit. Twice now tightening the hose clamp has caused a little drip leak to occur on an otherwise leak-free fitting.
Are you over-tightening the hose clamps? Are you sure the hose clamp is completely over the fitting? If it is not, could be pulling the hose off the fitting.
If it does not leak, you are happy with it, and it is not attached (directly or indirectly) to a thru-hull, there is no reason you need a clamp if you prefer not to use one. Just make sure you replace the hose at a regular interval.
I find it VERY hard to imagine the white trident that needed to be heated to get over the fitting will ever come off. It is nearly impossible to get them off when you want to.
Anything connected (directly or indirectly) to a thru-hull should have a (regularly inspected) hose clamp in addition as a saftey precaution. Just do not over-tighten it and it should not induce a leak.
Pacific Seacraft 34 #142
Seabrook, Texas
