05-19-2011
m-
I'm not at all sure of the spacing on your boat, but I would suggest disconecting the shore power form the breaker box. Install a new junction box, or a larger box, and then run the shore cable wires to the isolator, adding a new piece of wire (possibly cut from the one you have, if that works out long enough) to tie the new box back to the existing breakers.
In AC electrical work, and most land-based codes, you don't run splices in the AC wiring. Everything is joined inside boxes, and only continuous wire runs go from box to box. I have no idea what marine codes call for but would expect the same underlying logic to apply.
Either a new water-tight box, or a larger one for the breakers.
A conventional landlubberly electrical supply house actually SHOULD have waterproof boxes, they would be referred to as "explosion safe/proof" or "BOM" Bureau of Mines /DOT certified for use in explosive atmospheres (i.e. around gasoline and methane) if you can't find plain old fashioned "exterior" waterproof ones. Waterproof/exterior stuff usually isn't quite as waterPROOF.
