Old 05-20-2011
whorne is on a distinguished road
Bulb Wiggler
If I ever have a running light, mast head light, cabin light or any other light on my boat that is not working, the problem is almost always that the base of the bulb is not making a good connection in the socket. Wiggling the bulb makes it work. What's the deal? Is there a way to prevent corrosion on the contacts? Are screw in bulbs better than bayonett types? Do I need to upgrade my light sockets?
Thanks
Old 05-20-2011
southshoreS24's Avatar
southshoreS24 is on a distinguished road
clean the socket well and use some dielectric grease to help keep the corrosion down. also make sure its sealed as well as possible.
Old 05-20-2011
justified is on a distinguished road
+1 just like Southshore said
Old 05-20-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Electrical grease helps (sometimes a lot). However, if your boat is on the coast, in salt water and salty air, corrosion is something one can minimize, but never completely avoid.
Old 05-20-2011
RichH's Avatar
RichH will become famous soon enough
The usual problem is that the solder contacts on the bulb deform over time due to the pressure of the springs in the socket. This over time results in the contacts becoming 'flattened' or 'dimpled' resulting in poor contact.
Only fix is to replace the bulb with a new one .... OR add a bit solder to the deformed contact(s) to build the contact back to 'normal' dimensions.
Old 05-20-2011
Thank y'all so much for your help. I just got back from the store with some dielectric grease. I'll check for bad contacts as I apply the grease. What a wonderful thing it will be if my lights are reliable!
Old 05-20-2011
AdamLein's Avatar
AdamLein will become famous soon enough
Isn't dielectric grease an insulator?
s/v Essorant
1972 Catalina 27
Old 05-20-2011
You must have read my mind. Do I want something to put on the contacts that improves conduction or do I want grease that won't cause a short? What I have is made by GC Electronics and the label says "Specialty Silicone Compond...An excellent lubricant and dielectric compound.
Old 05-20-2011
AdamLein's Avatar
This issue has always bothered me. What Is Dielectric Grease? says
While the indicated use of dielectric grease calls for it to be used only on the non-metal parts of a connection, it has been shown to be effective at preventing corrosion when applied directly to the metal connectors as well. Care should be taken when using it in this way, because this application can, in some instances, cause the connection to stop working. A common reason for such a failure is that the grease has not been pushed entirely out of the way between the two points of contact.
So, if you're worried about your contact points deforming and not making good contact, I would think that adding an insulating layer in between and hoping it just "mushes out" is not a good idea.
Places if I have seen dielectric grease put to good use: the bolted-down contact points on the starter solenoid in my outboard. They were bolted down, and then the grease was applied over the whole thing (not between the contacts).
s/v Essorant
1972 Catalina 27
Old 05-20-2011
Thanks AdamLein, that was great information. I'm looking at my boat with my dielectric grease in one hand and scratching my head with the other :-)
LED Bulb Comparison !!! Maine Sail Gear & Maintenance 53 01-11-2011 09:38 PM
bulb bow skomani Boat Review and Purchase Forum 2 10-01-2009 06:51 AM
LED Bulb Experience rtblock1 Pacific Seacraft 17 08-18-2009 12:13 AM
navigation light bulb replacements Jmac62 Electrical Systems 1 03-23-2009 10:02 AM
Is adding a fin or bulb to a fin keel ok? rangeryacht26 Sailboat Design and Construction 10 09-12-2008 09:13 PM
