05-25-2011
Originally Posted by WhalePumps
The Gulper 220 pump usually last longer than two years but as it is a diaphragm pump we recommend you annually check the rubber parts to ensure no wear or tear. Unfortunately it looks as it the diaphragm has worn or endured a tear which has resulted in this water ingress.
Actually, the pump's directions mention inspection, but don't specify "annually". If I had to disassemble every mechanical device on my boat annually to check for "wear and tear" it would be a full time job! In any case, the diaphragm looks fine to me. No tears or obvious wear. Seeing the rust on the diaphragm bolt makes me think that that is were the leak was. Seems like the pump simply wasn't up to the job. Won't buy another. If anyone can recommend a replacement, let me know.
