Prepping topsides for Interlux Perfection - Page 3 - SailNet Community
post #21 of 28 Old 05-23-2011 Thread Starter
Just went and tested out the longboard sander on the filling compound that has now fully cured, and it seemed to sand and fair everything pretty efficiently. Taking into account the whole hull it would/will be a bit of a job for sure, but definitely not impossible...
harraik is offline
post #22 of 28 Old 05-23-2011 Thread Starter
Tommays: Sorry, I missed the 2 on there--it is 2333n that I used, which is what is recommended for Perfection.
harraik is offline
post #23 of 28 Old 05-23-2011
tommays's Avatar
I have to think the blue was gelcoat much like my boats bottom was green gelcoat
I dont know how to tell in a picture BUT the gelcoat is much tougher than paint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #24 of 28 Old 05-23-2011 Thread Starter
Roger that. Thanks for the input Tommays.
harraik is offline
post #25 of 28 Old 05-23-2011
mitiempo's Avatar
The blue layers are colored gelcoat which is used so the crew laying up the hull can see more easily that they are wetting out the layers. The center section that is translucent has no gelcoat left on it by the looks of it. I don't think, from the picture, that there was any paint on the hull at all. The glossy white on the left and right side of the picture looks like gelcoat to me. I think you sanded way more off than necessary. It actually looks like everything you removed was gelcoat.
Brian
mitiempo is offline
post #26 of 28 Old 05-23-2011 Thread Starter
Thanks as always, Mitiempo. So do you think a reasonable course of action is to fill and fair everywhere where I sanded too much away, and then just prep the rest with 80-grit and then prime?
harraik is offline
post #27 of 28 Old 05-23-2011
mitiempo's Avatar
Certainly if it is gelcoat, and from the picture it appears to be. Are you sure the boat was painted?
Brian
mitiempo is offline
post #28 of 28 Old 05-23-2011 Thread Starter
No I am not, I don't have much information about the history of the boat.
harraik is offline
Interlux Perfection Paint cbarison Gear & Maintenance 6 03-22-2011 05:10 PM
Where to buy Interlux Perfection? superiorvoyager Gear & Maintenance 24 03-01-2010 05:03 PM
My Interlux Perfection Recall FUBAR tommays Gear & Maintenance 2 03-30-2009 08:31 AM
Fixing my defective Interlux perfection tommays Gear & Maintenance 2 03-17-2009 09:48 PM
Interlux Perfection Varnish (2 part) mikehoyt Gear & Maintenance 0 05-31-2004 06:50 AM
