Old 05-22-2011
boltnbrew is on a distinguished road
TwistNLock not sealing
I need some insight on Jabsco twistnlock pumps. I have the twistnlock pumps on my heads, with a holding tank that fills from the top. I have begun getting backflow into the bowl.
Because the replacement twistnlock unit is not much more than the rebuild kit, and because it eliminates the chance of an incorrect rebuild, I bought two replacement pumps instead of a rebuild kit. Easy install, but no luck since I still get backflow- and the joker valve is new. How, exactly, is the twistnlock supposed to mechanically "lock" closed? What could be the problem here since most designs fill holding tanks from the top and create a column between the head and the top of the holding tank?
Old 05-22-2011
GaryHLucas is on a distinguished road
All reciprocating pumps need two valves, one intake, one discharge. The twist and lock pushes down on the intake valve, holding it against it's seat. So it seems unlikely a new one would leak unless something is actually stuck in it. Unfortunately it takes almost nothing to make them leak. If you have a vented loop and you pumped vigorously you should have pushed all the liquid over the loop where gravity will carry it to the tank. These pumps will pump air if pumped rapidly. It sound more like you have a head mounted lower than the liquid level in the tank, and the vented loop isn't really vented, so a siphon pulls the water back.
Gary H. Lucas
Old 05-22-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Check the toilet base unit ( where the pump unit fastens to the base ) sometimes you get a calcium type buildup that won't allow the plunger to seat or seal correctly
If you need to replace the base unit, they're about 40 bucks
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 05-24-2011
Thanks for the tips. One pump is brand new. I'll check the base for buildup. Would it interfere with part number 14 on the attached link or some other part?
Service Kits & Parts For Manual Toilets Cylinder Assembly, All Years
Thanks again for the help!
Old 05-24-2011
Would it interfere with part number 14 on the attached link ...........?
yes
1978 Tayana 37
Old 05-24-2011
got it. thanks again for the help - it's appreciated. Now to go digging !
Old 05-29-2011
That was it. New base about $45, together with new pump and lid and they're like new. Wonder how long that will last! Thanks again.
Old 05-29-2011
Do vinegar and veg oil once in awhile, the vinegar will help kill odors and helps desolves the buildup, veg ( or olive ) oil will help keep the seals & O-rings lubed
1978 Tayana 37
Old 05-30-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
A good resource for "head" issues:
The Head Mistress - SailboatOwners.com
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Sealing new deck to ?? vintageray Gear & Maintenance 1 10-20-2010 09:51 AM
Sealing my shrouds DwayneSpeer Gear & Maintenance 18 12-31-2008 09:45 PM
Centercase sealing Hartley18 Racing 5 01-17-2008 08:39 PM
Sealing Wood drynoc Gear & Maintenance 20 04-27-2007 11:18 AM
Sealing Windows nlowin Gear & Maintenance 8 03-30-2004 12:13 AM
