Old 05-23-2011
efiste's Avatar
efiste is on a distinguished road
Whisteling Sound Between 2800-3200 RPMs
When running my 1987 Catalina 34 Universal M-25XP diesel at about 80-90% of full power (2800-3200 RPMs), I hear a "whistling" coming from underneath the stern cockpit seat. There is no noticeable change in vibration. It does not sound like it is in the locker (although it could be) and it definitely does not sound like it is from the engine compartment. The sound does not occur at any other RPMs (above or below) and occurs on queue every time when within the RPM range. While under sail, I can also replicate the sound when reaching a certain speed. When this occurs, if I "lock" the prop (put the engine in gear), the sound stops. It seems that it must be from either the shaft's cutlass bearing or stuffing box.
1) Thoughts on which?
2) What advise should I heed: Can I operate the season with this situation? What should be avoided?
The boat is now wet without any easy access to have her hauled back out.
Thanks as always,
Eric
1987 Catalina 34 (Hull # 358) - Windbreaker
Old 05-24-2011
shogan50 is on a distinguished road
It sounds like your prop may singing. A friend just modified the trailing edge of his prop to solve the problem. http://www.hydrocompinc.com/knowledg...Propellers.pdf
Islander 30 MKII "Sojourn"
rpms quiz wsconner General Discussion (sailing related) 5 09-11-2010 08:35 AM
Parts for Danavigate 3200 rlewczuk Gear & Maintenance 1 12-04-2009 09:03 PM
FYI: I think RCR has a Sunfast 3200... eMKay Boat Review and Purchase Forum 0 02-08-2009 10:55 AM
$3200 and not sure what to buy????? jsamuels Boat Review and Purchase Forum 13 01-31-2003 05:41 PM
dufour 2800 neptunesrevenge Boat Review and Purchase Forum 0 08-05-2002 03:51 AM
