Epoxy on Non-Epoxy??? - SailNet Community
post #1 of 2 Old 02-11-2001 Thread Starter
What is your opinion of using epoxy glass systems (such as West Systems) on non-epoxy hulls? Specifically, I am considering building a chain locker into the bow of my ''82 USYacht 25. I''ve never had much luck working with vinylester resin, but have had good results with West Systems on smaller projects.
JWMOORE is offline
post #2 of 2 Old 02-12-2001
paulk's Avatar
The theory is that a large, strong, and stiff section of epoxy, like the bulkhead for your chain locker, set into a large, strong and bendy stretch of fiberglass, like a typical bow section, will cause problems with either hard spots in the hull or eventual cracking and delamination due to the different materials'' properties. Epoxy is quite brittle, compared to fiberglass, and will crack more easily than fiberglass when flexed. That''s the theory. Of course people fill nicks in fiberglass with epoxy all the time, but this is not a nick you''re filling in.
paulk is online now
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
polyester vs. epoxy for repair windship Gear & Maintenance 2 04-05-2004 05:55 AM
PVC and Epoxy billmac26 Gear & Maintenance 3 02-18-2003 12:12 AM
How do you fair a keel? lee_1999 Gear & Maintenance 5 04-26-2002 05:07 AM
