05-24-2011
First 1/2" seems way overkill for a 30' boat. My 36' boat specified 7/16" jib/genoa sheets, but I went up to 1/2 because I was having some slippage on the primaries.
If you're looking for something a bit higher tech than Stayset, Yachtbraid or XLS you might take a look at Yale's new Phd. I considered it for genoa sheets on my boat, but the rigger at APS disuaded me indicating he thought Phd was better suited to boats less than 35'. I ended up finding a deal on some 1/2" Samson XLS Extra T (which I think was discontinued), but was good for my requirements. XLS Extra T is a Dyneema/Polyester blend similar to NER's VPC but quite a bit more flexible. I have a VPC main halyard and like the line for that purpose, but worried about how it would run when used as a sheet as its fairly stiff. Both VPC and XLS extra T offer much less stretch than straight polyester, but at lower cost than the full on racing products.
I also chose to use Trophy Braid for the mainsheet, even though its stretchier than the other lines I chose. Trophy Braid's cover is super grippy and feels great in the hand, so I thought that made good sense for the mainsheet on a cruising boat like mine. I think it would also be a decent choice for genoa sheets on a cruising boat if you didn't mind a bit more stretch.
Finally, if you have a roller furling headsail I'd also consider going with one length and attaching to the sail in the center with a larks head. I went to that arrangement this year and am happy with it as there is less to hang up in a tack.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
