Old 05-24-2011
Nilaya is on a distinguished road
Forestay adjustment with Hood drum roller furler
Anyone familiar with the Hood Seafurl roller furlings? How much has to be disassembled in order to reach the turnbuckle under the drum in order to adjust the forestays (cutter rig)? We're fairly new boat owners and are currently in a remote area of Panama where there are few resources such as experienced riggers.
Old 05-24-2011
knothead's Avatar
Hood made a bunch of different systems. If you would post a picture of yours, I could talk you through it.
Ron Paul 2012
"wikijar"
Old 05-24-2011
Hood 253 & 253.5 Furlers
Here's some pics-two of the foresail and one of the staysail. (Please ignore the embarrasing condition-we're working on it.) Sure appreciate your help.
--Laura
Forestay adjustment with Hood drum roller furler-foresail.jpg   Forestay adjustment with Hood drum roller furler-hood253.5.jpg   Forestay adjustment with Hood drum roller furler-hood253-480x640-.jpg
Old 05-24-2011
BarryL's Avatar
BarryL is on a distinguished road
Hello,
I have no idea how much you need to do, but you can contact Hood here:
Pompanette LLC.
Customer Service location
7712 Cheri Court
Tampa FL 33634
Phone: 813-885-2182
Fax: 813-888-7421
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 05-24-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
I replaced the bearings not to long ago and posted the process and some links:
Sail Delmarva: Hood Seafurl 800 Bearing Replacement
Of course, you could have any model but the link will direct you to some drawings.
No, getting to the adjustment was not hard. A plastic set screw, pop out a few bits, and slide the furler up. You do not take the furler apart.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 05-26-2011
knothead's Avatar
You need to drop the sail, then remove the piece that connects the extrusion to the torque tube. (covered by the sail now). Then remove the hex head screws at the top of the stainless piece under the drum. Then the whole drum should lift up to expose the turnbuckle.
Ron Paul 2012
"wikijar"
Old 05-26-2011
Thanks for the responses. We have contacted Hood (Pompannette) and they emailed a pdf file of an assembly manual for a similar model so now we know how to disassemble most things, but still no clue what NOT to disassemble. Will lower the sail and try again. --Laura
Old 06-07-2011
Excellent help, thank you all especially knothead who had the details I needed. Will put it on my maintenance list to move the drums and clean at least once a year. --Laura
Hood roller furler RayWood Gear & Maintenance 6 02-24-2011 05:08 PM
Old CDI furler drum, have one? I need it! deniseO30 Gear & Maintenance 3 08-29-2010 10:44 AM
forestay turnbuckle conversion - furler NoWet Gear & Maintenance 19 05-11-2010 09:44 AM
Needed: Harken Mk III Furler Drum scraph Gear & Maintenance 1 01-11-2010 12:47 AM
Schafer Roller Furling adjustment? e31 Gear & Maintenance 2 10-10-2003 05:21 PM
