Old 05-25-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Will discharge hose get clogged?
Do you think my discharge hose from my head will get clogged if I put a 90 degree elbow fitting in? (super tight bend needed to get to holding tank)
Old 05-25-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
I think it's courting a clog. If there's absolutely no other way, then carry a toilet snake onboard with you to chop up and remove clogs.
S/V Old Shoes
1973 Pearson 30 #255
Old 05-25-2011
kd3pc's Avatar
kd3pc is on a distinguished road
Count on it...unless it is a "street L" that slopes correctly, but I think those only come 1.5" and up...
Old 05-25-2011
Chastened
Perhaps you could loop a coil in the hose in order to make the turn? Longer hose, but it'd be a smooth, circular path.
S/V Old Shoes
Old 05-25-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
I think as long as its smooth inside you may be OK. As long as your guests don't try and flush the wrong things.
Old 05-26-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Many heads have a 90 elbow off the back of them. Most heads can pump up to six feet. Depends on how far away your holding tank is, since 90 elbows create more friction than straight pipe.
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 05-26-2011
Barquito's Avatar
Barquito
Thanks for the input everyone. I haven't been able to find any gradual curved fittings that would work on the 1.5" hose. I think a big loop might be the way to go.
Old 05-26-2011
Chastened
I guess another option might be to step up your hose size in the middle, where the 90 degree elbow would be. If you could find some adapters to step up from 1.5" to 2.5" so that traffic flowing through the 90 degree elbow would meet less resistance, then you might be safe. Then, you use adapters to step back down to 1.5" to enter your holding tank.
Or if possible, adapt your holding tank hose nipple to 2.5" and just run the larger size as much as you can.
S/V Old Shoes
Old 05-26-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
Dometic sells a 90 degree kit. No idea what it is. But I'm guessing with thier super-stiff odr-safe hose it's sometimes needed.
http://www.dometic.com/b8fb91dd-d43b...a743483b.fodoc
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 05-26-2011
pdqaltair's Avatar
I just talked to Dometic anbout this. Nope, adding PVC is no problem. The kit is a dwv fitting with 2 smooth addapters glued in.
Go for it.
Clogged Head sailing320 Gear & Maintenance 11 10-18-2010 07:23 PM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 03:45 PM
Clogged seacock...please help! lowcountryking Gear & Maintenance 14 03-17-2009 01:32 PM
Fuel line clogged? davidpm Gear & Maintenance 3 05-15-2008 12:04 AM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 08:51 PM
