05-26-2011
Termite Fodder
Whilst John's idea is intriguing, because I'd like a backing plate of some kind, I'll go with Brian's idea for this.
Yes, there is a decent space between bulkheads, but the backing needs to completly cover the hole to prevent the filler getting pushed inside - so a couple of battens wouldn't do. It never occured to me to just cut the backing plate in half to get it in place, but I knew there'd be a simple way to do it!! I must be getting old..
I have a similar, smaller, hole some idiotic PO blew in the galley bulkhead and I'll use John's idea for that since no particular strength is required and a backer there would look obvious.
Thanks, guys - two problems solved!
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
