05-26-2011
Speed/captive nut backing fiberglass?
The top of my pedestal is attached to the base with 4 self taping screws into the thin fiberglass of the base. Naturally, the holes are wallowing out and becoming stripped. I'd like to find a clip nut/speed nut like the ones used for sheet metal. The clip over the edge over an unthreaded whole and provide a tread for a sheet metal or machine screw to fasten to.
The problem with using the stock items found in Ace, etc., is that they are designed for much thinner material than the fiberglass edge that the top to the pedestal fits down over. Does anyone know of a source for such a clip that would work for fiberglass? I don't have an exact measurement, but I'm guessing the fiberglass is maybe 1/8" to 3/16" thick (it's a stock pedestal on a Beneteau 361, if anyone happens to know).
I much prefer this to epoxying on a nut or wood backing. These nuts provide access to the underside of all the instruments on the pedestal and the steering gear, so they need to handle repeated removal and installing.
Any suggestions or hardware sources would be most welcome!
Thanks!
2003 Beneteau 361, Pura Vida
