Instrument and Panel Back Lighting - Page 2 - SailNet Community
post #11 of 16 Old 05-27-2011
Just a quick cautionary note:
Whatever size fuse you use, make sure the wire size you use can handle the current.
My own rule of thumb is to have the wire sized to handle 180% of the fuse rating.
In short, donít use 22 ga. wire with a 10 amp fuse, the wire will smoke long before the fuse pops.
Here's a sizing chart:
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies
Tweegs is offline
post #12 of 16 Old 05-27-2011 Thread Starter
Beneteau F310 ~ APOTHIC
cghubbell's Avatar
Dock
I'm looking at more like a 1A fuse on 16 AWG, so the fuse is way less than the wire itself. These back panel LEDs have a tiny draw.
Beneteau F310 ~ Apothic
PYC, Lake Ontario
cghubbell is offline
post #13 of 16 Old 05-27-2011
nickmerc's Avatar
I have my Blue Seas panel backlight on a separate switch in one of the extra breaker positions. I have it supplied by the DC master on the panel with a 1A fuse. I do not find the light put out to be that much. Especially after sailing all day when I am beat. I just like to be able to turn things independently.
nickmerc is offline
post #14 of 16 Old 05-27-2011
mitiempo's Avatar
Tweegs
The smallest wire on a boat should be 16 awg.
Chris
The panel lighting is powered by the red and yellow wires on the Blue Seas panels. The yellow is ground. Run the red wire, which is 16 awg, to a switch like a Blue Seas toggle (4150) and back to the positive bus on the panel. The run should only be a few inches if the switch is beside or above the panel and doesn't require a fuse in my opinion. As shipped the panel lighting on Blue Seas panels is not fused.
Brian
mitiempo is offline
post #15 of 16 Old 05-28-2011
I put in a 1 amp a series circuit breaker in the top position of my DC panel to control the back lights...seen in the upper right position here (subsequently I managed to break the toggle off that particular breaker and it turns out Blue Sea no longer sells a 1 amp, so replaced it with a Paneltronics).
sidmon is offline
post #16 of 16 Old 05-28-2011
mitiempo's Avatar
That is a good option if you have a breaker position to spare. I don't believe Chris does.
Brian
mitiempo is offline
Instrument panel came right out zAr Gear & Maintenance 9 07-13-2012 08:50 PM
Yanmar instrument panel source -used? mbsl98 Diesel 3 05-10-2011 12:30 PM
The new instrument panel tommays Cal 0 04-30-2011 05:47 PM
instrument panel & erratic tachometer neilsty Electrical Systems 1 09-25-2010 08:02 PM
Sailing: Wild Oats clinches back-to-back victories (New Straits Times) NewsReader News Feeds 0 12-28-2006 08:15 PM
