  #31 (permalink)
Old 06-01-2011
TropicCat's Avatar
TropicCat is on a distinguished road
I own a boat with 2 Yanmars and would like to suggest something no one else has mentioned.
My engines are very sensitive when using old diesel fuel. In fact it causes the symptom you mention. I would suggest a cheap fix by tossing a couple of gallons of new diesel in the tank and add a stabilizer. I use 2 stabilizers.
Stabil to extend the fuel life and Diesel Clean to add the lubosity lost in our low sulfur diesel fuel at the pumps these days.
It can't hurt.
Tropic Cat
  #32 (permalink)
Old 06-01-2011
sandycohen's Avatar
sandycohen is on a distinguished road
Hi TropicCat - Thanks for the input. Unfortunately I can report that I put about 5 gallons of new, marina grade diesel in with an additive last month, and the tank is only about 20 gallons so that's a pretty good share.
  #33 (permalink)
Old 06-02-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Tropic Cat may still be on the right track. Diesel fuel will polymerize as it ages. This makes it burn more slowly and often results in incomplete combustion (basically, the longer the molecular chains the slower a hydrocarbon will burn). Adding some new diesel will help, but if there is enough really old fuel in the tank the soot could be a result of this incomplete combustion of old diesel. Microbial growth in the tank will make things even worse.
I would take a look at a sample of the fuel from the tank and compare it to some fresh diesel. If the difference in clarity is dramatic (as in, one look makes you wonder how the engine ran at all), replacing ALL the fuel and cleaning the tank may be in order.
How to deal with exhaust soot on transom? EO32 Gear & Maintenance 23 06-05-2011 12:30 AM
Black oily exhaust Unmicky Diesel Engine Forum 8 06-03-2011 01:39 PM
Pitch Black Exhaust Water Yanmar 2GM20F rireefguy Gear & Maintenance 14 03-03-2010 08:13 AM
Yanmar - black smoke in exhaust JSL3 Diesel Engine Forum 18 07-20-2009 11:23 AM
Black Exhaust Stains On Transom eyebbober Gear & Maintenance 15 10-12-2004 11:15 AM
