The Jabsco Macerator... a ticking bomb of nastyness - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 06-01-2011
So is there a better alternative besides a cedar bucket?
Centerboard: Inaccessible moving parts surrounded by salt water.
Macerator: Inaccessible moving parts surrounded by raw sewage.
There's a common theme there.
hellosailor is offline
post #12 of 23 Old 06-01-2011
Irrationally Exuberant
Actually, this is one of the advantages of composting toilets--you will never be threatened by or messing with liquid black waste.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #13 of 23 Old 06-01-2011 Thread Starter
n0w0rries's Avatar
ugh... just reading this post makes me shudder and gag a little.
Caribbean 50 Ketch
n0w0rries is offline
post #14 of 23 Old 06-02-2011
Yes marine sanitation (esp repair) has to be one of the worst parts of living aboard. I second the foolproof cedar bucket recommendation especially while underway at sea where it won't affect your neighbors... Porta potties can also be great alternatives to holding tank/ sewage repairs. I have all three systems on my boat.
Mariner777 is offline
post #15 of 23 Old 06-02-2011
MARC2012's Avatar
When I went through that not certain which lingered longer the PTSD or the real or imaginary odor in the bilge.marc
MARC2012 is offline
post #16 of 23 Old 06-02-2011
Originally Posted by capttb View Post
.......I discovered mine on a Sunday morning in Avalon after a 4 day stay. Looked in the bilge and found the flourescent green dye they put in your tank on arrival. .......
I've always wondered if dye marking the black water tank would become a trend or requirement. I've never seen it done, but have heard many. Is this becoming more common?
I just recently dug deep enough under the Solon to even see where the macerator is located. It would be a bear to replace and it is one thing that I do not carry a spare. We're leaving next week for a cruise to Maine. Hope you didnt jinx us.
However, the discharge tube from the holding tank comes out the top with a fill tube to the bottom. Therefore, gravity can't dump it into the bilge. Nevertheless, a leak would be bad.
Jeanneau 54DS
Minnewaska is offline
post #17 of 23 Old 06-02-2011
the pointy end is the bow
erps's Avatar
I can see that consenting to some dye to use a private mooring ball or dock might be a condition for use, but I have a hard time with the notion that a person would have to consent to dye put in their tank just to anchor in a bay.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #18 of 23 Old 06-02-2011
mitiempo's Avatar
That has been the law in Avalon Harbor, Catalina for some years. Strictly enforced. California
Brian
mitiempo is offline
post #19 of 23 Old 06-02-2011
Originally Posted by n0w0rries View Post
I had the joy of dealing with a failing jabsco macerator this last weekend.
I wish I could get the addresses of the guys who designed it, so I could send it back to them in all it's stinking foul glory.
The thing is held together by 4 screws that corrode... not sure if it's the salt, or electrolysis, but when they fail it comes apart and you get black water in the bilge.
I had to cut it out and jam a plug in the hose, while 1 1/2 inches of nastyness flowed into the bilge. (either get it over with all at once or let it slowly drain!)
I used the thru-hull as a sweetening ****... flooding the bilge and then pumping it out... until it was clean.
I'm still suffering from post-traumatic stress from the whole incident. I ordered a shurflo macerator today... but I'm not sure if I'll be able to face the horror of replacing those hoses (might as well while I'm in there) and installing the new macerator.
If you have a jabsco macerator on your boat... it's just a matter of time until it fails. It will probably be on a major holiday weekend or your birthday weekend (or both as in my case)
I have never had the slightest problem with my home built composting head and the whole system cost me less than you paid for the macerator.
Just sayin.
knothead is offline
post #20 of 23 Old 2 Weeks Ago
Learning the HARD way...
eherlihy's Avatar
Re: The Jabsco Macerator... a ticking bomb of nastyness
My Jabsco macerator made an off-pitch whine when I last ran it in October. I just purchased a Raritan Macerator with stainless steel bolts as a spare. I hope that it lasts as long as my Jabsco, which has been on board and in service since before 2010.
eherlihy is offline
Atomic Is No Bomb sailnaway Atomic 4 9 10-21-2011 01:43 PM
Atomic bomb? Barquito Gear & Maintenance 15 05-07-2010 11:20 AM
Jabsco macerator pump not pumping just whinning. SanDiegoChip Gear & Maintenance 10 01-29-2010 03:17 PM
atomic bomb QuickMick Gear & Maintenance 20 12-10-2009 11:05 AM
Jabsco Macerator Pump aruggiero Gear & Maintenance 0 08-31-2009 02:56 PM
