Old 06-01-2011
casey1999 is on a distinguished road
Mast Steps and Halyards
Does anyone have a method to prevent halyards from getting caught in an enclosed fixed mast step? When raising or lowering my main, the main halyard gets caught on one or more steps, then I need to grab the halyard and try to swing it loose.
Old 06-01-2011
Siamese is on a distinguished road
When I had steps, I figured out that's what the steps are for!
Sorry...that wasn't helpful.
Old 06-01-2011
mitiempo's Avatar
A light line from top to bottom, attached at the outermost part of each step.
Brian
Old 06-02-2011
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
What Brian said. The PO of my boat did a really poor job of drilling holes on the outermost section of my mast steps. I ran steel wire through there three years ago and now I catch my halyards MOST of the time not ALL the time.
Old 06-02-2011
How would you attach without drilling the step? I was thinking using a heavy wire tie. I think I only need to do the top 1/3 of the steps. The PO used shock cord run from the step to the shroud stay cable and then back to the next step down. I was wondering what else might work.
Thanks
Old 06-02-2011
Tie on to the top step and hitch to each step below. Tie off to the lowest step.
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Mast Steps tdw Gear & Maintenance 34 07-31-2008 10:42 PM
ABI Mast Steps waltzingmatilda Gear & Maintenance 24 09-18-2007 09:44 PM
mast steps egregerson General Discussion (sailing related) 1 08-21-2006 01:04 PM
