Old 06-01-2011
timangiel's Avatar
timangiel is on a distinguished road
Bimini headroom
I would like to add a bimini to my boat. I have seen other boats with biminis in which the boom extends over the top of them. If I were to add a bimini that was low enough to do that, I would not be able to standup straight under it.
The other option would be to get a bimini that does not extend forward enough to interfere with the boom, then it could be made higher, but less of the cockpit would be shaded.
Are you suppose to be able to stand up straight under a bimini? I don't think I would be happy with one that I could not.
Old 06-01-2011
Cruiser2B's Avatar
Cruiser2B is on a distinguished road
I have been wondering the same thing. I think Boat design has alot to do with it. Seems harder to install one on older designs like my Alberg 30. I am going to add one even if i have to tilt my head a bit....sun just does a number on me. I have a great boom tent for times at anchor. After this weekend the # 1 priority is getting a bimini of some sort. i found alot of great ideas search the net. good luck
Old 06-01-2011
sck5 is on a distinguished road
I got a bimini I could stand up under. I cant imagine stooping every time I want to stand at the wheel. Get a zippered connector piece to connect the bimini to the dodger and you can have 100% coverage for shade when you need it.
Old 06-01-2011
Siamese is on a distinguished road
My Catalina 309 came with a bimini, and yes, you could stand up under it. Unfortunately, the boom would rub on it. When I lowered the boom to the point where the roller furling main would work properly, the bimini was a real problem. I was able to adjust the bimini low enough, but lost standing headroom. I didn't like that at all. IMHO it's a total pain to be hunched over at the helm, when docking, etc. My entire bimini and it's supports are now in storage.
Solution: I sewed up a flat awning (I have an industrial sewing machine, but this would be an easy job for your local canvas shop) that zips to the dodger and runs straight back. It secures to a couple PVC posts that I have attached to the stern rail.
The beauty of this system is that I can put it up or take it down in less than a minute. It just rolls up and easily stores. It doesn't have standing headroom, but that's not a problem, because I just take it down when I need to.
The problem with biminis IMHO is that they are too high. The higher the canvas, the harder it is to find shade under it. Lower it by a foot, and you dramatically increase the amount of shade. Example: Next time it rains, put an umbrella one foot over your head. Then move it three feet over your head and prepare to get soaked.
In fairness to biminis, it is possible to fold them up and lash them to the backstay. But it's a lot more difficult than stowing a flat awning. The trick was undoing all the straps that keep it under tension, etc.
It's all about how you use your boat, of course. Can't say that the awning will work for everyone or every boat.
When we're real busy in the cockpit, we don't use our awning. As soon as we're set for a longer run, up goes the awning, and we're in the shade. Approaching our marina, we just roll it up again.
Lounging in the cockpit at the marina is great with this setup. Again, because it's lower, we have more shade. The lack of standing headroom doesn't bother us. It's just a trade-off for greatly increased shady areas.
We can also adjust the height of the awning on the stern end. Very useful when you're sailing or lounging (or both!) and the sun's setting at the stern and trying to fry you. No more burnt neck sailing home at the end of the day. No more being blinded when you're enjoying a beer in the slip.
Another advantage to this system is it totally eliminates all the bimini "plumbing" (support tubing) that sort of surrounds the cockpit. Really seems to open it up. When you're sailing without the awning, there's nothing in the way. When we removed our bimini plumbing, it really seemed to open up the cockpit.
One downside to the flat awning is that it's more prone to flapping in a strong wind. In that case, we just take it down. Not often an issue, though.
Bottom line is that I'd gladly sell my bimini. The flat awning is better for the way we use our boat. Of course, on our boat, the bimini was a compromise, because it tended to be in the boom's way.
I would say though, that if I had no canvas in the cockpit, and my boat would allow either a bimini with standing headroom or a flat awning, I'd choose the flat awning. Both for its versatility, and in the real world, for the fact that it would cost a LOT, less.
Old 06-02-2011
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
Siamese, i would realy like to see pictures
Old 06-02-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
Would recommend the canvas to canvas twist connectors.Zippers break down in sunlight.marc
Old 06-02-2011
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
Definitely a trade-off. We went through the same process when making our bimini, which was further complicated by the fact that our main sheet is attached at the bridge deck. We opted for headroom over extended length, and I'm glad we did. I often drive the boat standing up to see obstructions in the water. We are in the process of making a canvas piece to zip between the dodger and bimini when we are not sailing and can move the mainsheet over to the rail. This will give us better sun/rain protection when at anchor or under motor alone.
Old 06-02-2011
souljour2000's Avatar
souljour2000 is on a distinguished road
Great post Siamese!..I must now echo the "Pics please!" rant....pics please...pics please...pics please....
Old 06-02-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Bingo! You are buying a bimini for shade. If its too high, you lose a lot of the benefit, especially later in the day when the sun isn't directly overhead.
Another consideration is the length. I like to be able to see the main to check trim, etc. Too long and you can't easily glance up at the sail to see what's going on.
Old 06-02-2011
WanderingStar is on a distinguished road
Great post Siamese! I also removed my bimini for better views mooring and to cure a sore neck. I intend to rerig the canvas as an awning, possibly arcing it with pvc pipe. I'm also glad to be free of the hardware.
To bimini or not to bimini that is the question davidpm General Discussion (sailing related) 16 09-14-2008 10:05 PM
Headroom lacklustre Boat Review and Purchase Forum 10 10-25-2006 10:04 AM
headroom sandra Boat Review and Purchase Forum 7 07-04-2006 12:38 PM
Headroom ccannan Living Aboard 6 02-12-2003 04:39 PM
Headroom ccannan Cruising & Liveaboard Forum 2 08-12-2002 06:18 AM
