Raymarine Autohelm/Pilot ST4000 - Page 3 - SailNet Community
 2Likes
post #21 of 23 Old 11-13-2013
Re: Raymarine Autohelm/Pilot ST4000
Andrew,
To convert to a 2 wire, remove the small circuit board on the back of the motor. Solder two wires to the tabs on the motor and you are done.
Faster and Delta-T like this.
CaptainDan99 is offline
The Following 3 Users Say Thank You to CaptainDan99 For This Useful Post:
Andrew Thompson (11-15-2013), Delta-T (11-15-2013), Faster (11-13-2013)
post #22 of 23 Old 11-15-2013
Fisher motorsailor
Dan, thanks - had a look inside the motor/gear casing and can see what to do now. All I need now is a controller of some kind to drive the thing.....
Thanks for your help, much appreciated
Andrew
Andrew Thompson is offline
post #23 of 23 Old 06-04-2014
Capt. Dan:
I just posted a problem with my ST4000+. You may be able to help.
The head always reads 50 Deg. I disconnected the wires from the Fluxgate at the head and reconnected. Not help. I will disconnect and measure the resistance per the manual. Any thoughts or suggestions?
Thanks.
John
E-mail: jdad1234@optonline.net
jdad1234 is offline
Autohelm ST4000 Wheel pilot LouAnn34 Electronics 27 06-14-2016 10:32 PM
Autohelm ST4000 Plus problems Outrageous Electronics 47 01-23-2015 07:20 AM
Raymarine ST4000 Autohelm binding DrB Gear & Maintenance 15 11-10-2012 12:02 PM
AutoHelm ST4000 jheitzman Gear & Maintenance 4 09-27-2011 06:01 AM
Raymarine Autohelm ST1000 Problems And Raymarine Warranty petertribo Gear & Maintenance 9 07-27-2008 09:36 PM
