Old 06-02-2011
sailing320's Avatar
sailing320 is on a distinguished road
Windlass Problem
I recently had my motor rebuilt on my Imtra Lofrans Kobra, 12V, 1000W windlass and now when I use it the 100 amp breaker pops after 10 -15 seconds of use. I tightened down the motor as much as possible but when the motor starts up in turns about 1/2 inch. Also, the speed is slower then normal. I called Imtra 4 times over the last 2 weeks and left a message with no return phone call. Has anybody had this problem?
Old 06-03-2011
Omatako's Avatar
Omatako will become famous soon enough
Maybe its been re-wound to 24V?
Arthur C. Clarke
Old 06-03-2011
celenoglu's Avatar
celenoglu is on a distinguished road
ıf the number of wounds is less than the original the motor will request more amps, which means a lower voltage is needed. This might be due to the repairer.
New windlass? jrd22 Gear & Maintenance 10 12-23-2010 11:04 AM
windlass motor or battery problem? PatrickAlaska Gear & Maintenance 10 08-09-2010 12:00 AM
Electric Windlass Problem nk235 Gear & Maintenance 5 01-26-2010 11:34 AM
Windlass SailingEmporium CS Yachts 1 12-12-2009 07:31 AM
windlass wannasail Gear & Maintenance 12 10-04-2002 03:58 PM
