06-03-2011
Crotchety Old Member
This looks bad. We recently had our Genoa tear at the leach close to the bottom. We were able to use sail repair tape, which we used on both sides. It worked very well, and until we can buy a new sail, it will probably hold.
Be sure that you buy good quality sail repair tape and although some of what I have read doesn't require it, tape both sides.
Your problem is that you also have a hole. As tommays stated, you will probably need to patch that, and will need a sewing machine designed for sail sewing.
Capt'n Tom Living Aboard 50/50
S/V Footprints
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006.
Hey, if I can't be sailing at least I can be here!
