06-03-2011
The original post stated there was an inline fuse on the red wire, which should be the hot (+) side. The black wire goes to the (-) side of your battery bank and is probably grounded. So it looks like you DON'T have a fuse on the "grounded" side. That said, your radio will most likely work better if it is grounded and your manual probably says something to this effect.
To close the circuit, you would have an equal amount of current flowing through the red and black/red wires, so a fuse on either one would break the circuit if the radio malfunctions and generates an unusually high current.
For what it's worth, the original radio in my sailboat, installed by the builder, had inline "littlefuses" on both wires, in addition to its own breaker (on the + side). I just replaced the radio in my powerboat. It came with a single inline fuse on the red wire, which is connected to the battery + side.
Bottom line: Standard practice is to have an inline fuse on the red wire near the radio. It can't hurt to have additional one on the negative side, too.
