06-05-2011
Colin,
You didn't say if it is a 2 or 4 stroke or what year. If it is a 2 stroke
they are pretty simple. Motors from about the earlier or mid eighties
have solid state ignitions, IIRC, generally they either run fine or not at
all, ignition wise. So it is likely to be an over rich problem, based on
your description. A good shop should be able to verify the ignition
and determine what the fuel situation is. Short of crankcase seal
problems, which is rare, or an air leak in the hoses or carb, it probably
is a carb issue. Shouldn't take a shop more than an hour or so to find the
problem. I had a 15 HP Evinrude 2 stroke, same basic motor as the
9.9, ran it hard for 10 years, was running perfectly when I sold the boat.
Suggest you drain the carb if it is not going to be used for 2 weeks or so.
Dabnis
