Honda Generator not triggering charger - Page 2 - SailNet Community
post #11 of 20 Old 03-15-2012
sailortjk1's Avatar
Re: Honda Generator not triggering charger
Originally Posted by boltnbrew View Post
Final chapter. After reading some RV forums, the issue appeared to be the Honda "floating ground" or some call it a "floating 110". Because the Honda is not truly "grounded", the ground is allowed to float between the ground and neutral wires- producing what appears to be 62.5V on both the hot and neutral when compared to the ground. This means my charger/inverter did not see 120 (115) V and acted like nothing was there. Solution: bond the ground and neutral wires inside the generator using a jumper. Just like what occurs in your household panels. Now all is well, the generator generates, the charger charges and no stray shock or other bad stuff.
I believe this is the same reason that I get a reverse polarity light when I use the Honda to power up the boats 110 Side.
I too am interested in how you Bond the ground and neutral inside the generator.
I was thinking of making a special power cord and twisting the two together to be used only as a power cord used in conjunction with the Honda generator.
Courtney is My Hero
sailortjk1 is offline
post #12 of 20 Old 03-15-2012
mitiempo's Avatar
Actually I am correct. 26 amps AC at max charge and the DC output is 130 amps on a Freedom 25.
Even a small charger like a Truecharge2 40 amp version uses up to 9 amps AC and the Freedom 10, the smallest in the Freedom series uses 12 amps AC at max charge.
Specs below.
Brian
mitiempo is offline
post #13 of 20 Old 03-15-2012
Boltnbrew
Thanks for the great detective work. Im havin the same problem with my
Honda 1000i. I was thinking it had something to do with the generators inverter not being Sine Wave but your info seem to jive with my testing.
I knew as i read the thread that the info you were getting was incorrect but didn't have the correct answer to chime in with.
Mitch
PS seems to me you could just make the connection in the cord from the generator to the boat. what do you think?
mitchbrown is offline
post #14 of 20 Old 03-15-2012
I vote the boltnbrew explanation. Portable gensets have no real "earth" ground, and chargers and other devices that are intended to be fed BY real earthed AC mains power, are always going to find some way to beat you up over that.
There are of course pros and cons to joining your earth and neutral. If everything was happily working without doing that--except for the AC light not turning on--I'd just plug in a nightlight and label it "AC ON" and not mess with joining the neutral and ground.
hellosailor is offline
post #15 of 20 Old 03-15-2012
Hello sailor
The honda's are an inverter charger which seems to put them into a whole different way of opperation than a standard generator. Not exactly sure how they work but im guessing they generate a low voltage current and then an inverter changes it to a stable 110 volt 60 cycle power.
The 1000i and 2000i thats what the i stands for INVERTER
Mitch
post #16 of 20 Old 03-15-2012
I've had my Honda 2000 about 2 years now. The only problem I had in the beginning was, as soon as the charging would start the Honda would cut out. Upon checking the battery charger I saw an adjustment that controlled the amount of amperage in could accept. It was set at the max, 106A. It seems that the charger was asking for more than the Honda could supply, so I lowered it to 85A and it's been working fine ever since. Sorry for the laymans explanation, hope this helps. I've read that combining the 2 wires makes for a safer setup, but I'm not sure how to do it.
Marc
gershel is offline
post #17 of 20 Old 03-15-2012
Don Radcliffe
There is a logical explanation of the OP's experience with his Honda gen and the floating ground--his boat is probably dangerously mis-wired.
The 30 amp shore power cord has three conductors--Load, Neutral, and Earth. The Honda is wired to put out 110v between the Load and Neutral, and the Earth is not connected. The outlet on the dock also has 110v between the Load and Neutral prongs, but the Earth is connected to the Neutral at some point in the Marina.
If the OP's boat saw power at the panel and inverter from the dock power, but didn't see it from the Honda until he jumpered the Earth to the Neutral, that means his dock power cord or boat wiring has crossed the Neutral and the Earth. This is VERY unsafe, particularly in fresh water. If he doesn't understand this, he should get an electrician to check out his boat as soon as possible.
BTW, if the Freedom load is too much for the Honda when the batteries are depleted, you can set the maximum current the Freedom charger will draw through its remote--read the manual.
donradclife is offline
post #18 of 20 Old 03-15-2012
Don R
Thats all okay but doesn't explain why he is getting 62.5 volts on the both the neutral and hot.
Mitch
post #19 of 20 Old 03-15-2012 Thread Starter
Don,
I had a marine electrician at the boat and it was all good. I originally had the same concern as you note. The reason the charger wouldn't work was because iit wants to see 115 between hot and neutral. The Honda design doesn't do it at way - unless you force it by jumping neutral and ground. All plug polarity is now testing correct at both the dock and aboard the boat, and my GFCIs work as they should.
Mitch- You could "jump" at the cord/ plugs, but that would be a little hokey and likely not safe. I fabricated a proper pigtail and connected the wires inside the generator.
Here is a good source for info on the Honda generators:
http://autos.groups.yahoo.com/group/...00_Generators/
Thanks for all the great comments and ideas!
boltnbrew is offline
post #20 of 20 Old 03-16-2012
ebs001's Avatar
Specs below.
Actually you are correct, my apologies
ebs001 is offline
Replacing Trickle Charger with 3 stage charger jasoncandace Gear & Maintenance 6 10-17-2010 07:27 PM
Honda EU1000i w/ProTech-4 1250 charger paulberto Electrical Systems 4 05-31-2009 09:46 AM
Help Please Honda 3000, or Yahama gas generator Popeyensweetp Electrical Systems 0 03-21-2009 04:23 PM
Honda Generator Gas Conversion EuphoriaOz Gear & Maintenance 2 02-09-2008 07:20 AM
Honda EU2000i Generator - Life expectancy GeorgeIP350 General Discussion (sailing related) 1 09-11-2006 11:33 PM
