Old 06-07-2011
dhays's Avatar
dhays is on a distinguished road
Remove deck pad eyes
Hi Folks,
This is a very elementary question, but then I'm simple-minded. When I bought Legacy it had lifeline webbing. It was one of the first things that we removed when we took delivery. Unfortunately, it left in place a lot of these small stainless pad eyes that are screwed into the deck, both in areas with gray non-skid as well as areas with white gel coat.
These pad eyes are annoying. They catch your feet and provide a place for dirt to accumulate. I want them gone. I can take them off easy enough, but what would be the best way to fill the resulting holes that will not only prevent any water intrusion into the deck core, but also look reasonably decent. Here is a photo of one on the deck.
47*20'11.7" N
122*35'20.8" W
S/V Legacy, Catalina 400 MkII, Hull #328
My Blog on
Old 06-07-2011
john1066 is on a distinguished road
I'd fill the screw holes with a thickened epoxy - West 403 or 406 - and 'stipple' the surface with the end of a paint brush to try and match the deck surface. When set, touch up with the appropriate paint colour if the natural off-white of the epoxy is too obvious.
John
Old 06-07-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
If you mask the hole with a bit of masking tape with a hole punched in it (hole punch) the work tends to go faster and neater. Get a smaller hole punch that nearly matches the screws.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 06-07-2011
ramminjammin is on a distinguished road
drill out the holes to provide fresh material to bond to
Old 06-07-2011
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
All of the above and I will add that Marinetex comes in WHITE as well as black. White is much better to use on a light deck, ask me how I learned that one.
SV S.S.R.I
It's my happy pill
Old 06-07-2011
What I don't get is why didn't they simply attach the webbing to the perforated toerail in the first place??
(doesn't help you, I know, but just sayin.....)
1984 Fast/Nicholson 345
Old 06-07-2011
pdqaltair's Avatar
Quite possibly.
One thing you don't know is what the PO used for bedding; if he used silicone and it's in the holes (probably) then some clean-up is surely needed.
Old 06-07-2011
puddinlegs is on a distinguished road
Probably because someone told them that the toe rail might break.
Old 06-07-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
You will need to cover the epoxy with something as epoxy is damaged by UV. Best would be gelcoat, but paint is OK.
Old 06-07-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
Marine Tex comes in gray. http://www.westmarine.com/webapp/wcs/stores/servlet/SiteSearch?Ns=Most%20Popular|0
What could be easier?
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Trust your eyes, not the GPS jackdale Seamanship 62 09-16-2010 01:57 PM
How to remove fiberglass resin from non-skid deck traumadoc Gear & Maintenance 3 08-29-2009 08:57 PM
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
Replace Teak Deck or remove Myblueheaven Gear & Maintenance 2 11-04-2004 06:23 AM
