Old 06-08-2011
TSAKUS is on a distinguished road
What size rivets?
I need to put new rivets in the mast on my Newport 33 as some of the rivets holding the conduit in place have come out and the conduit is banging around in the mast making quite a racket. Anyhow, I was wondering what size (both diameter and grip) rivet I should be using? Thanks
Old 06-08-2011
tommays's Avatar
I just put in a new one with 1/8 BUT you have to go with whats there
Using Knotheads advise to drill and extra 1/8 hole and use a bent 1/8 rod to pull it tight against the mast worked really well
You have to carefull with the lenth as a long a rivet will hold the conduit in place BUT make it diffcult to pull wire in or out at some point in the future
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
aluminum or stainless rivets? caver504 SailNet FAQ's 8 10-07-2010 07:14 PM
Rivets! polson Gear & Maintenance 10 04-19-2009 09:19 PM
This old mast & rivets and screws tommays Gear & Maintenance 10 02-03-2009 02:23 PM
Monel rivets Turk123 Gear & Maintenance 2 02-20-2004 02:45 AM
Rivets Tom Wood Gear and Maintenance Articles 0 08-20-2000 08:00 PM
