When is Diesel Bad? - Page 2 - SailNet Community
post #11 of 14 Old 06-10-2011
Senior Slacker
SlowButSteady's Avatar
I replaced the original mild steel tank in my 1975 Cal recently (the bottom had basically rusted through) with a polyethylene unit from Vetus.
It will never corrode, and a quick glance through the cockpit locker tells me how much diesel I have.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #12 of 14 Old 06-10-2011
mitiempo's Avatar
I thought about a plastic tank but because the tank isn't supported underneath I decided on stainless. Originally it was strapped to the underside of the cockpit. My new tank is in the same place but has vertical flanges that are bolted to the wood running fore and aft under the cockpit sole.
Brian
mitiempo is offline
post #13 of 14 Old 06-10-2011
Diesel is more stable than gasoline, but it is still a blend of many ingredients, some volatile, some unstable. If you prevent biomatter from forming, prevent condensation from getting in, there are still apparently volatiles that have evaporated out, and other chemicals that have decayed and turned into varnish and sludge.
If it runs it runs, but if any fuel has been sitting around for two years without stabilants being added? I think I'd rather take it to the waste oil tank and let it be burned off as heating fuel.
hellosailor is offline
post #14 of 14 Old 06-10-2011
RichH's Avatar
Assuming this is DIESEL and NOT GASOLINE.
The advice of discarding it (by putting it into your home oil burner tank, etc.) is a good one. The reason is that most of the contamination in diesel fuel will most likely be a fungus species whose 'spores' can easily pass through a BaJa type filter.
That stated, 'many' successive 'filtrations' through a Baja (or even a 'stack' of large paper drip-coffee filters !!!!) will significantly lessen the 'bio-load' of particles.
What you should consider to do if re-filtration is your choice is to filter and refilter and refilter (many times through the same filter) so that when you put the oil into a clean glass container and hold it up between your eyeball and STRONG light ... you see no HAZE in the fuel. This will insure that the 'distribution' of remaining particles will be 'mostly' below 5然; the 'naked eye' wont be able to 'see' particles (haze) smaller than 5然 and the fuel by then will be close to 'optically clear'. The reason for the 'target of optically clear' is that such particles typically 'agglomerate' into larger and larger particles (grow in size!) over time and then will if 'alive' simply re-infect the tank. This will allow you to 're-start' with fairly 'clean' and particle free (greater than 5然 removed) fuel.
Q - When is Diesel fuel bad? Answ: - when its not 'optically clear' when you hold it up to STRONG light and you see a HAZE (or worse).
Your "racor" should be a 10然, not a 2然... and the small engine mounted 'guard' filter should be 15-17然. If you get a lot of rust and other 'hard' particles (from your usual fuel supplier or from rust etc. from the tank) then the system should be tank --> 30然 ---> 10然 ---> 15-17然 (guard filter mounted on engine).
Summary: filter and filter and re-filter the fuel until optically clear, then add an enzyme type 'stabilizer' or 'tank cleaner' to the fuel. Thats it, youll be good to go. Plan on cleaning out the tank every year or so.
Note: if you can, wipe your fingers on the inside of the tank ... if your fingers pick up black slime or any 'heavy black', this is a fungus colony and HAS to be cleaned out as cleaning up the oil will be of no benefit until you remove the fungus that is using the oil as its nutrient source. The 'black' is usually a 'mat' of dead cells and resinous by-products of the organisms metabolism --- has to be 'removed' ... or you WILL have 'filter problems' later on.
The 'easiest' way to clean out a small tank is to take it to a 'radiator' or 'heat exchanger' shop and have it 'ultrasonically' cleaned.
Hope this helps. ;-)
RichH is offline
Diesel fuel lines -Universal 3cyl diesel argofred Diesel 8 04-18-2011 03:39 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 11:52 AM
