06-10-2011
If in doubt, I would aggressively get all the old sealant out, fill the hole entirely with epoxy, then redrill the holes. If the broken gel coat is under the base, I would just cover that with epoxy as well. If you will see it, it will require a real repair.
Jeanneau 54DS
