Old 06-10-2011
jakesokol is on a distinguished road
Rigid Boomvang mast and boom fitting
I was hoping someone might have had this same scenario and could help. I have purchased a rigid boomvang (spinlock VX1350) and my boat, a C&C 34 does not have a mast or boom fitting in place and I do not know where I could purchase such. To this point my only option would be to have a custom fitting manufactired for both the mast fitting and teh boom fitting which would be very $$$. Any suggestions on where i could find a fitting product would much appreciated.
thank you in advance.
- Jake
Old 06-10-2011
Try Garhauer ... This post shows some semi custom parts for just that purpose..
http://www.sailnet.com/forums/gear-m...tml#post739091
1984 Fast/Nicholson 345
Old 06-10-2011
MarkSF is on a distinguished road
Yes I just installed a Garhauer and it came with brackets to fit the mast and boom. When you order you send them a profile of your mast and boom and they make the brackets to fit. All I had to do was drill and rivet.
Old 06-10-2011
Smile
Thank you Faster and Mark SF. Was it expensive? So, you needed to take a profile of the boom, did you for the base of the mast too?
Old 06-10-2011
Garhauer Marine Hardware -2693930
Old 06-10-2011
swadiver's Avatar
swadiver is on a distinguished road
Templates of the aft part of mast and the underside of boom. A simple way of doing this is to take a piece of soldering wire and bend it around the aft part of mast, then trace the shape onto a piece of paper. Repeat the process on the underside of boom.
Scott
Long Beach, Ca.
s/v Namaste - 86 Catalina 30 , Tall Rig
The optimist expects the wind. The pessimist complains about the wind. The realist adjusts the sails.
Old 06-10-2011
You'll also need to tell them what size pins are on the ends of the vang so that the attachment points can be made to match.
Old 06-21-2011
Whisker pole
ANybody know where you can find a telescoping whisker pole for less than a fortune. I have a C&C 34 and I am getting killed on the downwind legs of the Wednesday night club racing.
thank you,
jake
Installing rigid boom vang - rivets or bolts? MarkSF Gear & Maintenance 6 04-15-2011 03:59 PM
Installing Rigid Boom Vang piccadeli Gear & Maintenance 3 02-02-2010 04:37 PM
Boomvang in Wood Boom and Weather Helm sideyb Sailboat Design and Construction 9 03-13-2009 07:32 PM
Garhauer Rigid Boom Vang teshannon Gear & Maintenance 12 09-29-2008 03:44 PM
Hi-Low Reefer/Rigid Boom Vang CapnSantiago Gear & Maintenance 6 07-17-2007 08:53 AM
