Old 06-11-2011
jobrantley's Avatar
jobrantley is on a distinguished road
Bright Yellow Oily discharge from Mermaid Marine Air Conditioner
Hi all,
I have a small (5200 btu??) Mermaid Reverse Cycle air conditioner/ heater in my small sailboat. I believe it was installed new in 2001.
It has worked flawlessly for me the past 5 years that I have owned the boat...until now.
During my spring recommisioning I noticed a bright yellow (almost neon) oily discharge that had appeared to leak from somewhere in the unit/pump. When I use the quarter turn valve (it is inline between the seawater pump and the ac unit) to help prime the pump I get the same discharge from it (along with the seawater).
I used the AC the other night and it seemed to work fine for at least 8 hours but when I woke up in the morning only the fan was running with no cooling. There was a minimal amount of the bright yellow/neon oily discharge below the unit.
Is this a refrigerant leak (form the ac unit) or a lubricating oil leak (from the water pump)????? Could something have frozen and cracked during the winter that caused this?
thank you for your thoughts and help with this,
Jon
Old 06-11-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Sounds like you may have a leak in the condenser since its showing up in the cooling water. Pretty sure the yellow stuff is oil, and the leak has also allowed the refrigerant to escape. Contact the manufacturer. My guess is you need a new condenser.
Old 06-11-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
Originally Posted by jobrantley View Post
Hi all,
Jon
Yup. The refrigerant lube is dyed neon to make finding leaks simple. It's really bright under UV.
Sorry.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 06-12-2011
jobrantley's Avatar
thank you guys for the info........gotta get to work on this before the next heat wave
Jon
Old 06-13-2011
hellosailor's Avatar
Jon, FWIW if you are seeing oil (yes, the bright yellow is leak detection dye) now, you are also losing refrigerant and if you can actually SEE it, there's a major leak. The good news is that a $50 UV light kit will tell you where that dye is coming from and where the leak is.
the bad news is that every time you use the system, the gas expands out, and when you shut down the system sucks in air and moisture--which will form acid and damage the system from the inside. So the system really should not be used in this condition at all, until it can be purged and refilled.
Old 06-13-2011
deniseO30's Avatar
Lies about her age
Do check the name plate information. I'ts most likely 134 refrigerant which is yellow. On such a newish unit I'd think and wonder about electrolysis in the heat exchanger coil. It's unlikely the mfg put dye in a new machine although 134 does look neonish. caution, it's somewhat caustic to plastic and rubber. and DON'T get any in your eyes. If the leak is indeed in the HX it's most likely easier to replace the HX then try to fix it. ANY hvac tech should be able to handle it.
Old 06-13-2011
jobrantley's Avatar
thank you for the additional info. I am going to contact and HVAC tech when I get back in town on Monday. Anybody have any good recommendations in the Annapolis/Deale area????
thanks again!
Jon
Black oily exhaust Unmicky Diesel Engine Forum 8 06-03-2011 01:39 PM
Onboard Marine air conditioner question manhattan08 Gear & Maintenance 6 04-20-2010 08:01 AM
Anchor Marine Air Conditioner Manual? Isaac-1 Gear & Maintenance 5 01-03-2010 03:04 PM
Eastern Marine Corp. Air Conditioner randall2v General Discussion (sailing related) 0 07-21-2004 03:27 AM
Oily Bilge dscottl Gear & Maintenance 3 06-11-2002 11:29 PM
