06-15-2011
One thing you should keep in mind is to use a surface clean prior to step 1 to remove any waxes,oils and grease so your not melting (basicly) them into the surface when you sand and then sand ,vac and wipe again prior to step 5
0340 is good for this as it wont damage the finish like a de-waxing or degreaser solvent will, if it's cured enough to sand it's cured enough to wipe with 0340; Also, 600 does sound a bit much, maybe cut back to 320
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
