06-15-2011
LP (length perpendicular) is determined by establishing a line at exactly 90°, perpendicular, to the luff* running through the clew, ... has nothing to do with the head (ring).
What he's describing is to one segment of the 'centroid of area' .... finding the exact midpoint along an 'edge' (luff, leech or foot) and drawing a line from the opposite 'corner' TO the midpoint along the opposite edge ... the intersection of all three lines establishes the centroid of area - aka: center of effort or CE.
* in actuality this is an 'imaginary' luff, as with jibs/genoas there is usually some material that is cut away in a smooth curve to compensate for forestay, etc. sag ... and with mainsails some smooth curve added to match the expected mast 'pre-bend'. So to calculate LP, you construct an imaginary line running between the tack and the head (an imaginary luff), then establish a line at 90° to the 'imaginary line' that bisects the clew.
