Fresh Water Drain Points on Perkin''s 4-108 - SailNet Community
post #1 of 10 Old 07-21-2003 Thread Starter
Fresh Water Drain Points on Perkin''''s 4-108
I would like to flush the fresh water system on my Perkin''s 4-108 engine, but cannot find all the drain points. The manual says there are four but I can only find 2, the one''s on the exhaust manifold. The manual says there is one on top of the head but I cannot find it.
Can someone tell me where the other two are?
Thanks.
Tony
ABullard is offline
post #2 of 10 Old 07-21-2003
I read through my Perkins overhaul manual to get an answer for you. Unfortunatly the manual didn''t mention where any of them were. I get the impression that there are several configurations to this engine so they may be avoiding the subject.
On my 4-108, I have drained the fresh water at the heat exchanger, which is the lowest point in the system. I know there are coolant hoses going to the hot water heater, so they could also be a place to start flushing.
When you re-fill it''s important to make sure the air gets bled out of the system to avoid air pockets. I read somewhere that the drain on the exhaust manifold should be opened to allow the air to escape.
I''ve been running a 50/50 mixture of antifreeze/corrosion inhibiter, and the coolant has always been nice and clean for the two or three years between changes.
You didn''t mention why you want to flush? If it is a heating problem, the heat exchanger is probably a better place to start.
Fairwinds,
Jim
joub is offline
post #3 of 10 Old 07-22-2003
Not to totally change the topic, but, how different/similar are the Perkins 4-108 and the Westerbeke 4-108?
Mclion71 is offline
post #4 of 10 Old 07-22-2003
Hi Tony,
can''y help you on the Perkins... but did you see my query about M39 waterlines on the Mariner forum? i was hoping you, already loaded down for liveaboard, might have some advice....
happy sailing
Stacey
www.svnamaste.com
namaste04 is offline
post #5 of 10 Old 07-22-2003
The Perkins 4-108 started life as an industrial engine.Many are in use to power portable heavy duty welding machines etc. Westerbeke, marinized the engine by adding a water cooled exhaust manifold,and whatever else they deemed necessary to convert the Perkins to marine service (as they have with a number of other manufacturers engines). At some time Perkins decided to provide their own marinized version using their own add on accessories to convert it to marine use.
It is my understanding that aside from the equipment used by each manufacturer to convert the engine to marine use, the basic engine is still Perkins 4-108.
joub is offline
post #6 of 10 Old 07-23-2003
Does this mean that some accessories from Westerbeke might fit on the Perkins 4-108? E.g. heat exchanger, etc?
mcain is offline
post #7 of 10 Old 07-23-2003
As you look at the front of the engine, there is a drain spigot that looks like a mini faucet at the back of the block, left side. If you do not have the spigot there than you will find a dead plug that will accomplish the same thing. All are marinized a little different depending on the year, mine has the fuel filter and lift pump on top of it and if yours is the same then it is hard to see.
phunter is offline
post #8 of 10 Old 07-24-2003 Thread Starter
Thanks a lot. I am sure it is in a difficult, had to get to location. Just like most everything else.
Tony
ABullard is offline
post #9 of 10 Old 07-24-2003 Thread Starter
Hi Stacey,
Somehow I missed your question on the waterline. When the surveyors examined my boat they stated that the boat drew 6 feet of water not the advertised 5.5. I suspect that is because the former owners, who lived aboard for 18 years had to add 6 inches of bottom paint to the waterline.
Hope this helps.
Tony
ABullard is offline
post #10 of 10 Old 07-24-2003
>>Does this mean that some accessories from Westerbeke might fit on the Perkins 4-108? E.g. heat exchanger, etc? <<
It seems logical that they should, but I''ve no personal knowledge of what can be interchanged.
Jim
joub is offline
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 05:42 PM
Fresh Water System Cleaning and Maintenance kcoffey Gear & Maintenance 2 07-13-2004 01:36 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 10:08 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 05:17 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
