Like Tree1Likes
Old 06-15-2011
deniseO30's Avatar
Lies about her age
My Hurth is supposed to....
go in gear when the lever is moved to fwd or rev, right? Well today it did not.. was in fwd when the engine was started after short sail in light air. I put it neutral, the rev. then fwd, raced engine it "caught" then it was OK.... Y'all know that "feeling" one gets in the pit of the stomach? ck the fluid. added a little. It's been ok since that one time this afternoon. We motored over to curtains wharf for dinner )about a half hour motor one way fwd and rev worked as always when entering the slip too. Soooo I'm a bit concerned now
I will ck the cables.. but I don't think it's them.
Oh. it's a universal 5416, Edson wheel and ped.
Old 06-15-2011
Our Hurth has done similar things from time to time... seemingly mostly when cold. In between it seems fine.
1984 Fast/Nicholson 345
Old 06-15-2011
deniseO30's Avatar
Lies about her age
I wonder, about these transmissions as they are called.. pretty simple compared to a typical 5 speed in a car or truck right? Do boat transmissions have a clutch of some sort? and it engages at a certain rpm? I read allot.. syncros, rings and things inside the case make it all happen right?
Old 06-16-2011
deniseO30's Avatar
Lies about her age
I actually lost sleep over this event
Old 06-16-2011
Stu Jackson's Avatar
Stu Jackson is on a distinguished road
I can understand losing sleep...
Reply #17, here: Transmission?
And also Reply #5, here, Transmissions 101: Props and transmissions
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Old 06-16-2011
deniseO30's Avatar
Lies about her age
So... Now I'm going to think the trans is slipping every time I motor the boat anywhere LOL
Old 06-17-2011
deniseO30's Avatar
Lies about her age
Did some checking today.. shift cable does move the shifter arm fully. When it's put in gear the trans now starts the shaft turning within a fraction of a second. So I guess I'm ok for now. But this leads me to ask when does one know it's time to rebuild a trans?
Old 06-17-2011
When was the last time you changed the transmission fluid? It's usually very dark when it comes out, per one of those links, so you really can't tell too much, however, if you sift the old fluid through a strainer, you'll see if there are any "particles" and if so how big they are.
Basically, these things last forever and are pretty robust.
Since you've checked it out as you've just reported, and slippage would first be suspect in the cable.
Sleep more, worry less --- I know, easy for me to say!
Old 06-17-2011
Large Member
mdbee is on a distinguished road
An ignorant question from a trailer sailor with an outboard.
Are these types of transmissions similar to auto/truck "automatic" trannys? Fluid pump, filter, bands, plates etc? What type of fluid do they use? What do they use for cooling? Or are they more like a "standard" transmission?
I know on auto/truck automatics fluids should be changed before they get very dirty and they shouldn't be changed if they are very dirty. Many times the new fluid will finish off an old transmission.
One "miracle in a can" is Trans-X. It can soften up harden seals that are leaking (and loosing pressure) and get the trans working again. Good product for cars, don't have a clue about these boat trannys.
Old 06-17-2011
fcsob is on a distinguished road
It can not hurt to change the fluid. It will not damage a trans to change the fluid, even if it is dirty. I personally use synthetic fluid in my engine & trans. Do not add rebuild in a can. when it's done it's done. Check you cables & change the fluid it can't hurt. 35 years certified auto tech.
Steve
Hurth HBW-5 Transmission KVK Diesel Engine Forum 11 06-27-2010 02:15 PM
Hurth HBW-5 won't shift mwielicki Gear & Maintenance 1 04-16-2010 11:55 PM
Is a propane Solenoid supposed to be hot ??? Sailormann Gear & Maintenance 15 05-27-2009 11:31 AM
Hurth HBW 50 vs. ZF-5, ZF-6 or ZF-10 Pub911 Gear & Maintenance 2 02-03-2009 07:44 AM
Hurth tranny on way to DOA halyardz Gear & Maintenance 1 09-09-2002 07:40 AM
