Old 06-16-2011
eastcoast31 is on a distinguished road
Bukh DV20 + BW6 Transmission PROBLEMS
OK... so whats the go when the gearbox gets stuck in reverse? Goes into forward and neutral no problem - can do it all day long. But gets stuck in Reverse and will not come out... force away... wont budge.
Turn the engine off and it clicks into neutral - GO FIGURE.
Has anyone had any gearbox shifting problems with the Bukh DV20+BW6 combo?
Old 06-16-2011
tdw's Avatar
tdw tdw is online now
Super Fuzzy Moderator
Have you had a chat with Bukh Australia ? Raven runs a DV24 and over the years I have rang and asked quite a few questions about that engine. They have always been forthcoming with the info.
Need Parts for BUKH 8HP starboardyacht Diesel Engine Forum 9 09-23-2011 01:31 PM
Bukh engines GBurton Gear & Maintenance 33 03-13-2011 11:49 PM
Bukh DV-18-ME running cold zerubb Diesel Engine Forum 1 06-07-2010 07:16 PM
Urgent Bukh Dv10 warwicksail Gear & Maintenance 9 01-12-2008 11:40 AM
A4 / Bukh DV20 swap russ1302 Atomic 4 0 04-06-2007 11:17 PM
