Old 06-16-2011
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Lanocote thinner?
I have a spray bottle of Lanocote that I have not used. It has been on the boat for three years. It must be well sealed because the plastic bottle is partially imploded because solvent has been lost over time. It does not spray. Any suggestions for a solvent I can add back to thin the stuff out so it can be sprayed?
Down
Old 06-16-2011
glassdad is on a distinguished road
If it won't spray it is probably bad. For $10.00 i would just replace it.
s/v Odyssey
Catalina 30
Old 06-16-2011
hellosailor's Avatar
Lanolin is water soluble, but if you check the MSDS or call the company, you can find out what solvent they preferred. Could be alcohol or naphtha, easiest to find out what they used and match it.
kerosene/thinner? wiseleyb Gear & Maintenance 18 02-12-2009 04:04 PM
Lanocote vs. Loctite bwindrope Gear & Maintenance 4 03-23-2008 02:05 PM
Lacquer Thinner - Safe around fiberglass? Finallybuyingaboat Gear & Maintenance 1 10-12-2007 03:24 PM
