Old 06-16-2011
Irrationally Exuberant
arf145 is on a distinguished road
Check those screw pin shackles!
I just don't trust these things and might replace all instances with the cotter pin variety. We were motoring along this weekend - no wind! :-( - when I noticed something funny in my mainsheet blocks. Why is one of them dangling in the air? Because the screw pin had come out of the block shackle, that's why. Could have been bad if it had happened while we were sailing. And *both* screw pin shackles that attached our swim ladder to the transom handily undid themselves this past winter--looked like the boat was trying to dismantle itself.
Anyone use Lock-tite on these? Or just go to something more positive?
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-16-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Seizing wire is your friend.
Old 06-16-2011
So, seizing wire through the hole then wrapped around the other side?
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-16-2011
puddinlegs is on a distinguished road
...or a zip tie.
Old 06-16-2011
Senior Slacker
Like so (although, I generally give it two or three wraps):
Old 06-16-2011
Duh on me! I looked at that hole and just thought "Great they have a way to keep from losing the pin, but not keeping it in". Wasn't thinking about wire. I suppose a circular cotter pin might do it too. Thanks, SBS.
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-16-2011
LinekinBayCD is on a distinguished road
You might want to check the shackle that attaches your anchor to your rode also. For sure that needs to seized.
The screw pin shackles are in general for items that will be semi-permantly attached such as an anchors, blocks that will not need to be un-attached frequently. Something like a swim ladder which you would use frequently (not up in Maine) could just be lashed or maybe use a snap shackle.
Old 06-16-2011
I'll be checking them! The swim ladder was a strange arrangement. The shackles were just used by a PO as a way to put a pin through the ladder joint while not having quite the right size pin. Got rid of the shackles and replaced with pins through the joint that take a circular cotter pin.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-16-2011
hellosailor's Avatar
Seizing wire or loctite. If you break the bank and buy a couploe or three bottles of loctite (blue, red, and intermediate) and get in the habit of putting one drop on every screw before you thread it...It's an easy habit to stay in, and stuff just doesn't come loose much after that. Or seize.
Old 06-16-2011
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
We've got only one of those on Abracadabra that I can think of, off-hand. It's on the top block for the mainsheet. Thinking... Yeah, that's the only one, I think. *shrug* I just put a pair of pliers on it and snug it down well. I usually have a pretty good feel for torque and how stuff "feels," and, while I suppose the thing could come loose, it hasn't yet.
Maybe I'll take it loose, put a dab of Loctite on the threads, and snug 'er back down, just to be safe.
Jim
s/v Abracadabra
1976 Pearson P30
Mooring shackles Hudsonian General Discussion (sailing related) 2 02-04-2011 01:22 PM
Get mooring shackles off Barquito Gear & Maintenance 8 10-06-2010 05:02 PM
Windlasses and shackles teshannon Gear & Maintenance 22 09-05-2007 05:00 PM
Shackles for the Mainsail LakeEscape Gear & Maintenance 6 07-20-2007 07:56 AM
EquipLite Shackles verticalmoves Gear & Maintenance 0 05-14-2002 09:49 AM
