06-17-2011
Originally Posted by hellosailor
junkrig, there are no composting heads for small craft. They're misnamed.
What you've got are "separting heads" that collect urine in one container and feces in another. You're left to haul a bucket of partly decayed fecal matter off the boat, instead of having a liquid waste tank pumped out. It's still sewage.
IF you've got enough room for two "composting" heads, you can allow the feces to actually compost for 4-8 weeks while you use the second head. Then you probably will have real compost, that you can dump in your garden. And switch back to using the other head while the second one composts.
It's not semantics, it's intentionally misleading marketing, and it is still RAW FECAL MATTER that you're dealing with. That may be more convenient to handle and dispose of than a waste tank, but it still ain't compost.
I don't think you can say that they are misnamed. The composting does in fact take place in the heads. It's just not completed unless, as you stated, it sits awhile.
For heads like mine, which is a simple bucket, (I no longer use the separating seat) I prefer to simply say containing head.
You're right about the fact that it's much more convenient and sanitary as well as a lot less smelly to empty than a waste tank. That is unless you are off shore and simply pump it over the side.
Ron Paul 2012
"wikijar"
