Is the 6 wire cable full of thin little wires, or heavier gauge (like the anchor light wires). If they are thin little wires, it probably was or is wind instruments. If they are heavy gauge, they could be other lights.
Do you have a steaming light? Do you have spreader lights or other deck lights? Do you have wind instruments? What's the inventory of stuff when you look up?
If the lights aren't burnt out, an ohm meter should read some small resistance (continuity) between the pairs that are connected to the lights. There could be a common ground, so by pairs, their could be a single wire that pair's with many lights. If you get convinced that these are lights, not wind instrument wires, after finding the ones with continuity, you could try connecting a 12v source to the appropriate pairs and figure out what lights up.
Another clue would be if there is a terminal block near the mast base. If so, you can try your breaker panel switches and see which terminals produce 12 volts when you flip the switches. If someone was kind during initial installation, the wire colors might even match at the terminal block with your mast wires. But that would be lucky
I'd do all these easy experiments before sending someone up.
