06-21-2011
" 22.6 Volts"
David, I expect that's a typo for 12.6?
Only the battery maker knows the exact number for their battery chemistry, they all vary a bit. 13+ means there is either a float charge still on the battery, or a bad meter. 12.8 would be surprisingly high for a brand new battery no matter who made it.
If you really want to trust your meter, you do need to use a calibrated meter. Either lab calibrated, or bought new and calibrated when made (i.e. a pricey Fluke) or you need to find a way to calibrate it, something to compare it to. And then you need to find out the limits of your meter.
Some may be rated accurate to 1/2% on the 20VDC scale, others to 1-2% plus or minus 3 righthand digits. So at a real 12.6 volts...You may see 12.4 on a meter that's only one percent off, 12.1 or 12.9 on a meter that's got more float in it.
I've got a spare disposable Harbor Freight meter, it's almost as accurate as a Magic8Ball. I keep meaning to pick up a Fluke, because my better meter still isn't in that class. But it isn't easy to find a "12" volt calibration source!
