06-21-2011
Super Moderator
JackDale said, "If the leech of the sail flutters, snug it up a touch whether or not it is new. It provides a little extra power and eliminates an annoying noise."
With all due repect to my esteemed and very knowledgable colleague, I would agree with most of what he said, such as that even a new sail needs its leechline adjusted until the flutter is removed. Assuming that the sail was cut properly, and the sheets, sheet leads, topping lift, vang, and traveller are adjusted properly, a small amount of leech line adjustment is all that should be required on a new sail.
I agree that doing so eliminates an annoying noise. Within reasonable limits, tightening the leechline enough to stop fluttering reduces turbulence and therefore reduces drag. On the other hand, tightening the leechline curls the trailing edge of the sail to windward creating more drag and increasing heel angle. Over tightening is not a good thing so you may want to experiment with easing and tightening until you get to a setting where it does not flutter but a small amount of easing will start a flutter.
Where I respectfully do not not agree with JackDale is that curling the leech will produce more power except within very limited conditions (going dead down wind).
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
