06-23-2011
Hmmm..there are so many ways to do this...note that fiberglass does not stick certain plastics (or wax). Your supplier can sell you plastic sheets, or I sometimes use the plastic found in retail "boxes". This plastic comes in very handy as the fiberglass touching it will set totally glass-smooth so when you peel the plastic off no sanding needed. If you use this plastic - perhaps with a bit of wood behind to make it more rigid - as a form, it can easily be peeled off when dry and reused. It will allow you to make more complex shapes.
In many cases I would agree with the WM guy, and start from the inside; that makes sense if you have a puncture hole; just tape the plastic on the outside of the hole, build up the layers on the inside, remove the plastic, your pretty well done. But in your case I think some more artistic rebuilding of the rail will be needed. As the damage is pretty severe, you may want to have the matting overlapping the hole on the inside and outside.
So an option would be to set up the plastic on the inside, and build up the layers on the outside; maybe using more plastic and a wooden form (thin ply) to help your final layers on the outside to follow a nice, smooth. matching curve along the rail. Then remove the plastic from the inside, and put a couple of layers of mat inside to reinforce it both ways. Perhaps a bit overkill?
BTW, Grinding is essential; people recommend a 12-1 ratio for a really solid repair, so put on the dust mask! And remember when applying that the cloth should we "wetted" with the epoxy (please tell me you are using epoxy...) not soaked. Too much epoxy is bad - but equally you don't want the fibers dry! You could buy a fancy roller, but I just use a scraper to make sure the resin penetrates all the fibers, and remove excess resin.
Hope this helps...thinking it through first is probably 75% of the work!
