Is this mechanic trying to pull one over on me? - Page 2 - SailNet Community
post #11 of 15 Old 06-24-2011
imagine2frolic's Avatar
Oh he's very competent. He managed to walk away with your motor. What he is not is honest. This is why I buy the manual, and learn for myself. At times I have a friend show me, and I learn even better. Damned manuals drive me nuts.
bl,
I just love your posts.......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #12 of 15 Old 06-24-2011
Send a message via AIM to HPLou
"The mechanic said he thinks it might be carburation and started spraying some of my carb cleaner in it while I pulled the chord."
It sounds like the engine got flooded with carb cleaner. Normally one would use spray carb cleaner with the engine running not as one would try to start an engine. Probably have to change the plugs in order to get the engine started. You may have to use a spray starting fluid to get the engine started again. If that doesn't work, the carb may have to come off for a rebuilding. Good luck.
HPLou is offline
post #13 of 15 Old 06-24-2011
You can't just leave the engine and not pay the bill or you will never see it again, they will repair it and lien sale it to themselves.
The average mechanic rate here is about $100/hr so you are not necessarily getting ripped off in that regard. I'll pile on here though, if you didn't think the guy knew what he was doing you shouldn't have let him take the engine.
FWIW, there are several things that would cause the engine to POP. Assuming it was not mechanical, a lean condition caused by gummed up carb jets, exhaust valves being out of adjustment, exhaust leak etc. My vote would be for a gummy carb if it ran well when you last used it. Spraying carb cleaner into the throat of the carb to clean jets is about as effective as pouring drain cleaner into a manhole cover to clear the sink drain in your kitchen. If plugged, the carb needs to be disassembled and cleaned.
An engine will run with very low compression and you can't always diagnose that with a pull on the cord if the engine uses an automatic decompression system for starting. Somebody more familiar with your engine may be able to advise you about that.
Bottom line, if you have no confidence in the mechanic get the engine back before they can rack up big fees. Or let them fix it and pay up.
SJ34 is offline
post #14 of 15 Old 06-25-2011
MacGyverRI's Avatar
1st, I gotta raise my labor rate....
Compression may be "low" but still there. Is it a 2 cycle or 4 cycle?
2's are touchy w/ actual compression needed, especially at idle.
A simple Valve adjustment can cure most 4 cycles of bad idling.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #15 of 15 Old 06-25-2011
Well, Mariner, you've stepped in it and the only question is what your STATE laws are. That's what will determine how and whether they can lien your boat, whether they need a written work order and so on. If there's nothing in writing you may be able to demand your engine back and get it. Maybe undamaged.
Best to find out what your local laws are and who knows of the shop and their rep. You might be able to demand your engine back, and if you have any proof of ownership, bring back a cop to liberate it if necessary.
But from what you say...the mechanic certainly sounds full of something. An engine with "no" compression wouldn't have started, wouldn't have run. And would be most unlikely to just "lose" all compression from one day to the next, that wasn't what you'd originally complained about.
Might be simplest to walk away from it but again...you've got to ask locally.
hellosailor is offline
Pull-Pull Drive Unit for PDQ 36ft. Catamaran Classic mpdoane2 Gear & Maintenance 1 06-21-2011 09:15 AM
Do I really need to pull the mast out? Lidgard29 Gear & Maintenance 13 05-20-2010 07:26 AM
My first pull out. 1stBoat Gear & Maintenance 13 10-25-2008 08:34 AM
Pull the mast or not sailnaway Gear & Maintenance 6 01-15-2005 03:25 AM
