Old 06-24-2011
sandycohen's Avatar
sandycohen is on a distinguished road
Electrolytic Conversion Indications
Can anyone give me direction on how to check various metal parts of boat (DC wiring system, spars, keel, chainplates) for current that would be causing electrolytic conversion?
I've found some decent articles online about how to properly wire your DC and lightning systems, but nothing on how to know if you've got a problem to begin with. I have a 30+ year old boat that is new to me, and has alot of terminals connected to various metal parts of boat i.e. chainplates all over.
Muchas Gracias
Old 06-24-2011
Maine Sail's Avatar
You need a corrosion reference cell and a DC digital multimeter. The reference cell is made of silver/silver-chloride and they run anywhere from $100.00 to $250.00 depending upon where you find it. Make sure you get one with a long enough lead. Some are only 20 feet and pretty cumbersome in terms of use on a boat...
______
-Maine Sail / CS-36T
Old 06-24-2011
sandycohen's Avatar
Hi Again Mainesail and thanks for your help.
I've been doing some googling around and haven't found much - is this the culprit? Marine Reference Cell | Buckleys UVRAL
Do you know of a good article or reference on how to use it to detect electrolytic corrosion on boats? Again, I did do some searching, so not trying to be lazy.
Also FWIW I have no AC power connection so that isn't an issue.
Electrolytic action on aluminum spars johnseattle Gear & Maintenance 2 03-13-2010 06:04 AM
AH conversion MLM2 Electrical Systems 5 04-11-2009 02:14 PM
what is the conversion for blt2ski General Discussion (sailing related) 8 02-06-2008 09:52 AM
Refrigeration conversion Mahia Newport 5 11-15-2007 05:13 PM
Cal 27 Pop Top Conversion DonaldAdams General Discussion (sailing related) 2 07-10-2006 11:24 PM
