06-27-2011
Old as Dirt!
When I replaced the old head on our former boat, I used a 3/4" thick piece of Starboard as a spacer. I used the old head to duplicate the bolt pattern for attaching the Starboard to the base, hence the old stainless lag bolts could be used. I used the new head to duplicate the new head's bolt pattern and, using that, set the appropriate sized bolts, counter sinking the heads on the bottom face of the Starboard and locking nuts on the top face. The new head was set down on these "studs" and locked in place with cut washers, lock washers and finish nuts. The thickness of the spacer made no difference to use of convenience.
FWIW...
