06-27-2011
Originally Posted by mrjd1981
Hello, still rather new, but our catalina has a slight leak when in the water, maybe a half gallon every 4 hours. I've been trying to narrow down where its coming in from so I looked at the bottom today and saw a kind of plug? I looked over the C22 manual and it does not mention this. But from the inside of the boat behind where the drain and cable are for the keel there is a device with wires coming out of it, that use to go up to a box that just said "gain" on it. Which inturn was connected to a depth meter and speedomoter. (That are broken)
Rather then trying to repair the old system I took all the wires and gain box out. But what I am wondering is if the original thru hull sensor was taken out long ago and just a rubber plug put in? Its about 3inch in diameter.
I put some marine-tex around the seems of the plug and smashed it in pretty good. I'm curious to see if thats the cause of my issues.
I guess my question is.............has anyone else seen something like this? and does anyone else have any suggestions on where to look for issues with water coming in the bottom of a c22?
Thanks
The speed transducers normally come with a plug that you can put in, while you service the transducer. Note that a proper plug and the transducer should seal on a couple of radial O rings on the shaft, not at the top where the ring is.
If it has the proper plug, and it is leaking, you might be able to stop it by removing the plug and applying marine grease to the O rings. Obviously while you are doing this it should not be in the water as you will have a rather large leak
