06-27-2011
For my 30' 6500-7000 lb fin keel boat, I have a 7.5kg/16.5 lb bruce with currently 16' of 3/16" chain and 250' of 1/2" 3 strand. Then again, here in Puget Sound, you are usually in 40-100' of water when you anchor, add in upwards of 14' tides......... lots of rode is nice. I do plan to go with a bit longer chain and one size up. To a degree, the more metal be it anchor or chain, the better the holding.
I've also been toying with a race hook on the bow with a 7lb fortress alum, about 4-5' of 1/4" chain and 3/8" line in the 150' length too. Race rules require a min 6lb anchor and 10'ish lbs of total chain and anchor for myboat, one figure out how to get the best appearance bang for the buck when racing, vs cruising.
If I was in the Caribbean, Oz or other places with coral, the more chain the merrier! I might look at 50-60' and an appropriate anchor that would catch in coral/rocky bottoms. Or if it does not catch per say, at least have enough anchor and chain such that the wt might hold me.
If you need to go thru a hurricane or equal, again, a different anchor wt and chain. probably something in the 30KG/50 lb anchor and 75-100' of chain depending upon depth etc.
Marty
She drives me boat,
I drives me dinghy!
