shaft\coupling tolerance - SailNet Community
post #1 of 8 Old 06-29-2011 Thread Starter
TEAM ZISSU
drobarge's Avatar
I am replacing the propshaft coupling on my v drive. The propshaft is not a standard size and I need to have the coupler machined to a very slightly larger bore size. What should the tolerance between the propshaft and coupler bore be within?
Thanks
"who za sheet is kingsley zissou"...claus R\V Bellefonte
drobarge is offline
post #2 of 8 Old 06-29-2011 Thread Starter
TEAM ZISSU
drobarge's Avatar
+ .001 -.000 ? or is greater acceptable?
drobarge is offline
post #3 of 8 Old 06-29-2011
JimsCAL's Avatar
Connection between the shaft and coupling is usually a taper.
JimsCAL is online now
post #4 of 8 Old 06-29-2011 Thread Starter
TEAM ZISSU
drobarge's Avatar
Fairly certain this is not tapered. nonsuch 30 westerbeke 27 V drive
drobarge is offline
post #5 of 8 Old 06-30-2011
mitiempo's Avatar
I believe it is a press fit.
Brian
mitiempo is offline
post #6 of 8 Old 06-30-2011
Maine Sail's Avatar
It should be a light press fit if this is a straight coupling. It should NOT just slide over the shaft easily.. This fit is usually fitted by hand by the machine shop. I would suggest using a "split" coupling then the fit is not quite as critical but it should still be pretty snug on the shaft.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #7 of 8 Old 06-30-2011 Thread Starter
TEAM ZISSU
drobarge's Avatar
Ahhh forget it!
hauling boat, replacing shaft and all.
Thanks for the help though!
drobarge is offline
post #8 of 8 Old 06-30-2011
Senior in age only!!!
centaursailor's Avatar
A properly sized taper lock coupling should not present any difficulties . The taper lock bore is designed to tighten on the shaft as the taper is driven into the coupling via grub screws. Some systems also use a key to deliver the drive but that must be machined into the shaft.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
Rusted/Seized shaft coupling jarod Gear & Maintenance 4 04-29-2008 08:25 AM
Prop shaft runout tolerance voyagersail Gear & Maintenance 0 06-07-2007 04:25 PM
Flexible shaft coupling zerubb Gear & Maintenance 1 08-18-2006 11:13 PM
shaft coupling clifsail Announcements and Suggestions Box 1 08-15-2006 02:06 PM
prop shaft coupling kurt crowley Atomic 4 2 06-27-2006 03:45 PM
