Repairing Mast Bend - Page 2 - SailNet Community
post #11 of 18 Old 06-30-2011 Thread Starter
Thanks Brian but the Hunter 25 trailerable does not have a backstay. The rigger mentioned that Hunter uses proprietary tech in the mast spreader and shrouds that eliminates the need on this model.
Dijon is offline
post #12 of 18 Old 06-30-2011
Most Hunters have mast pre bend the larger ones are around 6" of bend with no tension, I'm not sure how much yours should be assuming it is a B&R rig with no back stay it is probably normal. if the mast is raked too far back this is due to shrouds & stays being too long/short not the pre bend in the mast. (try a shorter turn buckle on the forstay & retension)
cruisingdream is offline
post #13 of 18 Old 06-30-2011 Thread Starter
Thanks Brian but the trailerable Hunter 25 does not have a backstay. The rigger I consulted mentioned that Hunter on this particular model did not incorporate one.
Dijon is offline
post #14 of 18 Old 06-30-2011 Thread Starter
Thanks cruisingdream for your response. 6" is also the metric for this rig.
I currently have 11'' even with no tension on the shrouds and stays. I will retention the forestay (turnbuckle already quite short) within the furler but failing that was wondering if there is a way of taking the bend out of the mast without damaging it.
Dijon is offline
post #15 of 18 Old 06-30-2011 Thread Starter
Thanks Brian but Hunter did not include a backstay on this model. It is a B&R rig.
Dijon is offline
post #16 of 18 Old 06-30-2011
overbored's Avatar
If there is no back stay then you would have a pre bend in the mast which is required to get proper sail shape. I would check with Hunter and get the exact forestay length and measure the one you have. If a furler is installed there may be an extra clevis link at the bottom that is required when adding a furler which would make the stay to long to get the proper mast rake unless you have it shortened.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #17 of 18 Old 06-30-2011 Thread Starter
Smile
Thanks everyone for your assistance on this matter Dijon
Dijon is offline
post #18 of 18 Old 07-01-2011
mitiempo's Avatar
I see it is a B&R rig. Shrouds too tight probably as posted by cruisingdream.
Brian
mitiempo is offline
Inducing Mast Bend Grumpymx Gear & Maintenance 24 06-17-2010 10:11 AM
mast bend Piratesoul Irwin 0 07-20-2008 06:20 AM
N30 mast bend RussLeighton Newport 2 06-06-2008 08:21 AM
Islander 28 mast bend remlap Islander 2 04-24-2008 11:39 PM
Mast Bend offline2004 Gear & Maintenance 7 02-17-2006 10:50 AM
