06-30-2011
Senior Moment Member
Normal pre-paint prep - sanding, cleaning etc.
Very quickly after the last pass of abrasives, spray with zinc chromate to provide a seal and bonding surface for the topcoats. This is essential as it is the only thing I know of that sticks to aluminium. It is the chartreuse coloured stuff you see on aircraft internal surfaces and on Whale gusher aluminium pumps. This step must be done right away as aluminium oxidizes extremely quickly.
Paint as per usual when the zinc chromate is dry.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
